VM CZ 125 Hobby
Schattenparker
VM CZ 125 Hobby
Beitrag von Schattenparker »
hat jemand diesen Motor schonmal gefahren?
[img]data:image/jpeg;base64,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[/img]
Hans<<
Noci
VM CZ 125 Hobby
Beitrag von Noci »
Selbst gefahren nicht, aber wir hatten 2015 zwei von diesen Motoren bei einem Rennen dabei.
2,7 und 4,7 Sek langsamer als ich, zum 3. Rennen sind die beiden nicht mehr angetreten.
Guckst du <--
michel
VM CZ 125 Hobby
Beitrag von michel »
Man weiß aber auch nicht wie die Fahrerqualitäten waren :D
Noci
VM CZ 125 Hobby
Beitrag von Noci »
Das ist leider wahr :D
Ich denke für den Anfang sind die Motoren nicht schlecht. Kosten 1950€ Neu und sind recht robust.
Es gibt in CZ eine eigene Rennserie für diese Motoren, das ist doch was :D
Den New Line Kühler für 600€ und die Wapu sparst du auch noch ein.
Schattenparker
VM CZ 125 Hobby
Danke für die Antwort, das die Motoren nicht unbedingt mit den TM usw mithalten können ist eigentlich klar.
Aber der Grund meiner Frage war, wie Noci in seinem Beitrag geschrieben hat, günstiger Einsteigermotor für Hobbyfahrer, wo das größte Problem für schnellere Zeiten zwischen Lenkrad und Sitz zu finden ist
Hans<<
Noci
VM CZ 125 Hobby
Beitrag von Noci »
Wenn du mehr Info's zu dem Motor haben willst: http://auerracing.de
Der Vertreibt die Motoren in Deutschland.
Munez
VM CZ 125 Hobby
Beitrag von Munez »
Wer zahlt denn 600€ für einen New Line Kühler? ?(
ossi
VM CZ125 Hobby
Beitrag von ossi »
Wir sind diese Motoren gefahren. Wir hatten eigentlich vor einen kostengünstigen Hobbyfahrercup zu starten. Zur Probe starteten wir bei 2 Veranstaltungen der OAKC in der Klasse kz2 Senioren. Um die Kosten für Hobbyfahrer gering zu halten, wollten wir von Anfang an nur 2 Läufe pro Veranstaltung mitfahren. Auch suchten wir einen günstigen Reifen. Wir schrieben vom MK2 SHOP Daniel Mazur 4 Jahre alte Dunlop DDM vor. Leider waren wir mit den Reifen dann aber deutlich langsamer. Aber auch der Motor, der so an die 40 PS leistet, kann sich natürlich nicht mit einem Kz10c Spezial messen. Für Hobbyfahrer ist er sehr gut. Kolben müssen nach 10 Stunden gewechselt werden, nach 3 Kolben dann auch Pleul und Lager. Wir fahren 5 Motoren im Hobbybereich und sind sehr zufrieden. 2 Motoren sind bei Ebay zu erwerben, da die Fahrer dieses Jahr in die Kz2 wechseln. Eratzteile gibt es bei http://www.auerracing.de . Kolben und Kupplungsteile passen auch von tm und Maxter .
Schattenparker
VM CZ 125 Hobby
@Ossi
ja durch die Angebote bei Ebay bin ich neugierig geworden, ich kannte diese Motoren nicht und deshalb habe ich das Thema gestartet
Hans<<
