Weather Pod for Rotax max
Scheel
Beitrag von Scheel »
Want yo bay Weather Pod incl software for Rotax Max.
Best Regards,
Scheel
mail : A.Scheel@cook-wce.com
Zuletzt geändert von Scheel am Di 16. Jan 2007, 17:22, insgesamt 1-mal geändert.
TM86
Beitrag von TM86 »
i searched weather pod in some dictionarys but i cant find it. can you explain what a weather pod is please
Zuletzt geändert von TM86 am Do 28. Dez 2006, 12:58, insgesamt 1-mal geändert.
Scheel
MaxJet jetting software is designed for use with the Rotax FR125 MAX Sr, Jr and MiniMax motor using the Dell'orto VHSB34 carburetor in factory configuration including K27 and K98 needles, 5.2 and 3.6 floats, 8.5 and 12.5 venturi inserts. It is designed for ease of use and recommended for novice and veteran karters who wish to optimize the use of their RotaxMax motors in minutes. All versions can easily be connected to our RaceJet Pod for even faster results.
Introduced for 2007 is Float Level Management© and Water Temperature Management©. These unique feature available only in MaxJet permit you to get the most out of your motor package with the press of one button.
MaxJet comes in one of two packages: MaxJet for Windows and Palm an MaxJet for Windows and Pocket PC. As well, thanks to a partnership with a leading Weather Station provider, we have developed the RaceJet Weather Pod. An Air Force grade Weather Pod that interacts with MaxJet for accurate jetting every time.
http://www.maxjet.ca/html/for_fr125.html
funny4u2
Beitrag von funny4u2 »
Hello Scheel,
do you want to buy one or
do you sell it?
I don't need one.
Greetings
Jürgen
Christian777
Beitrag von Christian777 »
He said: Whant you buy a .....!!!! ;)
Ich glaub mal der Verkauft einen!!
mit motorsportlichen Grüßen
Christian
PS: Und nie den Grip verlieren ;)
Tobi@Toxic125
Beitrag von Tobi@Toxic125 »
Original von Christian777
glaub ich auch. i mean the same. but i think "whant" must be written "want".
Tobi
funny4u2
Bist Du Dir sicher?
Genau das ist die Frage!!!
Glauben kannst Du in der Kirche.
Jürgen
Christian777
Ja komm er hat sich hald verschrieben genauso wie yo des heißt you!!!!! ;)
Nimm doch nicht alles so ernst!!!! :D
Das leben ist ernsd genug!!!
Christian
Tobi@Toxic125
Original von funny4u2
Jürgen
bin ned so oft da. muss ich also auch daheim glauben.
boa, in reli hat mal die lehrerin wissen wollen, was glauben alles heißt
mfg Tobi
so scheise ich hab meinen pc wiedermal verstellt hilfe??? wie komme ich da weg??
Zash
Beitrag von Zash »
Vorsicht, kenne mich aus, bin mit einer Reli-Lehrerin befreundet - lach................
http://www.hh-kartracing.de
