Welches Baujahr Birel Chassi
Der-Hugo
Beitrag von Der-Hugo »
Moin
welches Baujahr ist dieses Chassi?
edit: hier noch mal bischen größer http://www.bilder-hochladen.net/files/b30o-1-jpg.html
Zuletzt geändert von Der-Hugo am 21.05.2009, 12:12, insgesamt 4-mal geändert.
schröder
RE: Welches Baujahr Birel Chassi
Beitrag von schröder »
1997-2002, da meines Wissens nach immer für 5 Jahre homologiert wird und die 02 auf das Jahr 2002 schliessen lässt.
Stutzig mcht mich allerdings die Kombination der Zeichen, da ab 2003 eine andere Art der Homologationnummer auf der CIK-Seite zu finden ist.
Schröder
Kartrider
Beitrag von Kartrider »
Würde ich auch sagen, so zwischen 1996 und 2002.
125er Schalter
Aiello
Beitrag von Aiello »
The model number on 2007 models is located on left bearing hanger
Where do you look to find the numbers?
From 1996-2002 the Serial number of the chassis and the product designation numbers were located on the left
side bearing hanger where the brake caliper attaches to the kart. In recent years it has been on the same bearing
hanger only on the backside of the hanger or on the wheel side underneath the axle. A plate is often welded on to
the frame with the Birel name and a series of numbers. That is the homologation details but the chassis model
might also be listed. There are numerous other models of Birels in circulation and we can assist clients who need
more information on a case by case basis.
Basic Model Information -
Each "chassis number"
is made up of a series of letters and numbers that
will give you an idea of whether the kart was built
with or without front brakes, what "model/chassis
design" it is, what size tubing it uses and a code to
determine the year
Front brakes or Not?
"C" - If the chassis number begins with a "C" - the chassis was designed as a shifterkart or a model that has front
brakes. This "C" would be incorporated at the beginning of the model code.
Model -
The next designator will be the MODEL. For Birel, the model will either be an "R" or an "M". The difference
will be visually in the outer main frame rails. A more traditional looking, two-bend design is the "R" - a single-bend
design is the "M".
Chassis Number / Tubing Size -
After the model number will be a series of numbers. Beginning in 2000, the
numbers correlate with the size of tubing used to manufacturer the kart. (25 = 25mm tubing, 30 = 30mm tubing, 32
= 32mm, 31 = a mixture between 30mm and 32mm, etc.)
Year / Year Designator -
For the shifter drivers who want to figure out the year your kart was produced here is a list of the models by year for
the 32 mm Tube shifter karts. The year designator will be located AFTER the tubing size numbers.
1996 - CR632
1997 - CR632B
1998 - CR832
1999 - CR932
2000 - CR32X
2001 - CR32Z
2002 - CR32V
2003 - CR32SR
2004 - CR32SP
2005 - CR32ST / CM32ST
2006 - CRx32 & CMx32SC
2007 - CM32SV
2008 - CR32SE
Zuletzt geändert von Aiello am 13.06.2009, 03:25, insgesamt 2-mal geändert.
www.info-kart.eu
BIREL CRX 32-S1 2009 -K9B Spezial GKS
CRG Road Rebell Racing 2007 -K9
